Max value in CFD post using function calculator or probe
Old   July 24, 2018, 09:53
Default Max value in CFD post using function calculator or probe
Kyle88 is on a distinguished road
Dear all,
I have a problem with calculation of maximum temperature of a fluid flowing in a pipe. I created a point of variable maximum (temperature) in a fluid domain and then used a function calculator to display temperature value at this point. The weird thing is that if I use a function calculator to show maxVal in the fluid domain straight away, I get different value compared to the probe method. Does anyone know the reason for this? Am I comparing node and centroid values or something like that?
Kyle88 is offline   Reply With Quote
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 23:07
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 06:06
From function void GGIInterpolation anton_lias OpenFOAM Running, Solving & CFD 0 August 28, 2012 08:13
Force can not converge colopolo CFX 13 October 4, 2011 23:03
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
