Wrong scale between ICEM and CFX in Workbench |
July 12, 2018, 09:46 |
Sebastian Schulze
Hi guys
I have a problem with the scaling between ICEM and CFX when I'm updating my project via the workbench in Ansys 18.2. The geometry is always 10 times larger than it should be. For example: I'm meshing a cube 0.3x0.3x0.3m in ICEM. Then i transfer ist to CFX-Pre with the workbench. Now I change the geometry to 0.5x0.5x0.5m. If i update the projct in ICEM with the yellow lightning, the geometry in CFX has the correct dimensions (picture1). But when i close ICEM CFX wants to update the geometry (picture2) and now the cube has the wrong dimensions 5x5x5m (picture3). The same happens if I update the project directly over the workbench. I've tried a lot of different thing to solve the problem (replay scripts, different units etc.), but it seems the the problem is caused by the workbench itself. Because if I save mit project in ICEM as a .CFX and import it manually in CFX it's perfectly fine. Best regards Borsti |
[ICEM] The ICEM Guide for CFX Users | JuPa | ANSYS Meshing & Geometry | 11 | September 4, 2017 10:43 |
[ANSYS Meshing] ICEM or workbench meshing? | ma. | ANSYS Meshing & Geometry | 3 | July 1, 2016 21:10 |
ICEM grids cell directly linked and output to CFX pre cell in Workbench | Pierre1 | CFX | 2 | March 26, 2015 10:22 |
[ICEM] Node Number vs. Node_ID & ICEM vs. CFX | Araz | ANSYS Meshing & Geometry | 1 | April 25, 2011 12:03 |
ICEM 10 mesh scale foe CFX | Korsh Mik | CFX | 2 | October 7, 2005 10:07 |
