ANSYS AIM : Measuring pressure values on individual section
Old   July 5, 2018, 07:30
Default ANSYS AIM : Measuring pressure values on individual section
Vinayak-
Vinayak- is on a distinguished road
In the sectional view of my fluid geometry, there are multiple regions separated from each other. I want to calculate average pressure values in each of those regions.
Example : Consider two pipes parallel to each other. The flow volumes through those pipes are also parallel. If we take a section plane across the pipes, two separate regions are formed in that plane.
Whenever I try to measure average pressure using pressure contour defined using my section plane, it shows the average pressure value of all the regions, not individual regions.
If I do the same thing in Autodesk CFD, I will get the average pressure values at each region of that section.
Like pressure at region 1= x bar, pressure at region 2 = y bar
Please help me find a way out.
Thanks,
Vinayak
Vinayak- is offline   Reply With Quote
Old   October 4, 2018, 04:14
Vestdam
Vestdam is on a distinguished road
When you create the plane, you can select which body to refer to. I think you have to make two planes, one for each domain.
Vestdam is offline   Reply With Quote
Issues with pressure drops and values KiruBiru CFX 2 November 24, 2017 06:34
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
