Using Windkessel model to control outlet boundary conditions
Old   June 13, 2018, 15:01
Default Using Windkessel model to control outlet boundary conditions
Megan Stevens
meganstevens is on a distinguished road
Hi, I am trying to use a 3-element Windkessel model to control my outlet boundary conditions. After reading through articles and other forums, I still have a couple questions I am hoping someone can help me with:
1) What programs do you use? Fluent/CFX, C/FORTRAN/MatLAB/LabVIEW?
2) Is there a way to write the user defined functions/boundary conditions so that it is coupled to the CFD? Ideally, the output of the CFD can be used in the UDF and iterate.
Thanks!
meganstevens is offline   Reply With Quote
Old   September 9, 2019, 19:01
Aashay Tinaikar
ARTisticCFD is on a distinguished road
Hii Megan,
Yes, there are provisions to write a UDF that is coupled to the solver. However, the CEL that you specify in Ansys might do that explicitly. I found the following thread which might be helpful to you.
Pressure outlet as a function of the flow rate (windkessel)
Ansys Fluent or CFX is good for simulations if you have the license. CFX has some nice and easy to use CEL while UDFs can be defined in Fluent using C functions. You can find a lot of literature about those.
OpenFOAM is a great and very powerful alternative. However, it has a steep learning curve.
ARTisticCFD is offline   Reply With Quote
ansys, outlet boundary condition, windkessel
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
