Inderjeet Singh
Rep Power: 9 ![]() |
Hello Everyone, i need to simulate the welding process and the thermal and mechanical properties of the welded plates.
Let me explain more... Two plates which are to be welded, are placed a little apart , and a roller is modeled just above. Actually welding has to take place with the movement of the roller on the two plates. The joint is formed by the relative motion between a rotating disc, which is applied with a crushing force, and two sheet metal parts. The process is known as Friction crush welding I have prior knowledge of Ansys fluent and have worked on some flow problems. However, i am new to Ansys mechanical/structural. Please somebody having any small knowledge regarding this simulation, please come put and help me and guide me. 1. Which module should i use ? 2. Boundary conditions 3. How to provide rotary movement to roller/disc + downward force ( Using UDF ? or something else) Any small help will be appreciated to progress towards the analysis. Thank you |
ansys, friction welding, mechanical, welding |
FSI simulation in ansys cfx | Arash67.m | CFX | 1 | September 29, 2017 09:52 |
importing an Ansys simulation | vortex69 | ANSYS | 0 | May 9, 2016 11:00 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
Fire Simulation Ansys Fluent (BBQ Smoker) | shaw600 | FLUENT | 0 | November 4, 2015 15:36 |
Ansys Workbench Thermal-Stress Coupling - 2D Hot Rolling simulation | Jeronimo97 | CFD Freelancers | 4 | August 23, 2014 20:30 |
