Kane Mitchell
Rep Power: 0 ![]() |
I am unsure on how to model an adhesive that is between 2 interfaces. As a quick background, I am investigating the bonding strength of road reflectors (link below). They are installed onto road core samples by a layer of bitumen. I am going to be testing these in a compression load machine and need to model this in Ansys first. I understand it is a complex thing to model but I just need some sort of preliminary results. I have tried simply making base of reflector as a fixed support but this is not right. I need to add in some sort of 'glue' or 'adhesive' between the 2 interfaces. Can anyone help me to solve this problem or at least give me some guidance? I hope my query makes sense and look forward to peoples replies! Kane. LINK TO PIC http://tinypic.com/r/14c5e07/9 Last edited by kanemitchell99; May 31, 2018 at 09:34. Reason: Added in link to photo, could not embed into post |
adhesive, ansys, glue |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
