Shihar
Rep Power: 8 ![]() |
Hi, I have got my CFD results in ANSYS 17.1. I need to extract my data from equally spaced points for each time step from the back of the cylinder as shown in attachment.
So I created these lines with X number of sample and then exported it to csv file. Is there a way that I can code in Fluent and create a lot of lines like these with X number of samples in each line and export automatically for each time step. Because I cant keep creating lines and exporting them and changing time for each time step as its not feasible. I know it sounds simple and I have tried other stuff as well but can't find an answer. Really appreciate it if any thing helps. Thanks. |
ansys, cfd-post, data, export, fluent |
[Gmsh] Structured meshing in Gmsh | the_phew | OpenFOAM Meshing & Mesh Conversion | 19 | August 24, 2022 04:19 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 05:41 |
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger | benru | OpenFOAM Meshing & Mesh Conversion | 3 | June 29, 2008 22:24 |
