How do I find the pressure drop in translationally periodic wavy channel flow?
Old   April 26, 2018, 18:03
Default How do I find the pressure drop in translationally periodic wavy channel flow?
Dev Fons
dfonseka is on a distinguished road
So I was simulating laminar flow in a 2-D wavy channel but I get 0 pressure drop between the translational boundary conditions. I calculated the pressure at the inlet and the outlet and found the difference and divided it by the length but I get meaningless results which I suspect to be incorrect. In addition I computed it alternatively by using the wall shear stress but I get meaningless results too. What should I do?
Does this also mean that my pressure data is invalid? Can I instead calculate the pressure a distance after the inlet and a distance before the outlet to calculate the pressure drop?
dfonseka is offline   Reply With Quote
fluent, periodic bc, pressure drop, pressure drop too small
pressure drop in a periodic flow myaccount FLUENT 0 March 25, 2014 00:58
Pressure drop in periodic turbluent pipe flow lou FLUENT 0 September 21, 2005 01:58
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
