April 7, 2018, 16:13 |
Get more data points
Swapnil Rane
Rep Power: 9 |
I've attached a graph image of mass flow vs time. I would like to get more refined results before time (5e+06s) or more data points.
Is there any way to do it? without changing the timestep size |
April 10, 2018, 23:20 |
Hello Swapnil,
Accuracy of mesh will improve the result. For more data points, plot the graph in preprocessing section of FLUENT and later, export the data points to acquire results. :-) |
April 10, 2018, 23:22 |
Thank you
Swapnil Rane
Rep Power: 9 |
Thank you........
April 11, 2018, 03:38 |
Gert-Jan
Rep Power: 28 |
What is this Graph about? What do you see?
You plot the massflow()@outlet versus time where time goes from 0 to 3e7 [s]. This is equal to approximately 1 year. Is this realistic? I find it hard to believe. |
April 11, 2018, 14:06 |
Model
Swapnil Rane
Rep Power: 9 |
It's a simulation of diffusion of gas in cork over a period of a year.
The graph is good. But with more data points, the graph will be better. |
April 12, 2018, 03:57 |
Gert-Jan
Rep Power: 28 |
You plot the massflow at the outlet. Looking at the type of graph, I think this is created in Post. I think (!) the number of points is limited to number of transient-files you saved during the transient run. My first guess would be 12 files , 1 for each month. Because Post retrieves the data from there (I think). So if you want more data points, you need to save trn-files more frequently.
WHy don't you create a monitor plot during your run in Fluent. That would be most logical. Then you get as many points as timesteps you make Last edited by Gert-Jan; April 12, 2018 at 04:38. Reason: You are using fluent instead of CFX. |
graph, mass flow, time |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 12:27 |
Arclength parameterization of a curve whose data points known | ipp | Main CFD Forum | 1 | July 11, 2011 15:13 |
Text input commands to add data points | Kathryn | FLUENT | 0 | November 5, 2007 18:38 |
XYZ (ASCII format) data points into GAMBIT | Neil | FLUENT | 1 | August 7, 2007 10:24 |
Saving data from monitoring points | Astrid | CFX | 3 | April 10, 2002 05:55 |
