HELP!! Dyanmic mesh UDF problem
Old   March 24, 2018, 17:12
Post HELP!! Dyanmic mesh UDF problem
Dilan
dilan23 is on a distinguished road
So i'm trying to have a dynamic mesh set-up for my mesh, the problem is i'm new to this and I was wondering if anyone could help me.
So i'm trying to make it so that the mesh expands by about 10% in all direction and this happens in a pulsatile manner (time dependent).
This is in an attempt to model the flow through an artery if it helps to make the problem more clearer. Thank you for your help.
dilan23 is offline   Reply With Quote
Old   April 21, 2018, 13:22
Default udf problems
abdo
khaledhmz is an unknown quantity at this point
curently im new in fleunt and i try to compile udf but i have some problems when i compile 3 udf file in the same time i got this error
..\..\src\work.c(195): error C2109: subscript requires array or pointer type
Generating Code...
can any one help me
khaledhmz is offline   Reply With Quote
dynamic mesh, fluent, udf
udf for valve closing a pipe using dynamic mesh chem engineer Fluent UDF and Scheme Programming 2 May 13, 2017 10:39
problem with UDF mesh broke takashi6120 FLUENT 0 March 16, 2016 03:53
Need HELP in writing UDF for a dynamic mesh problem farrux Fluent UDF and Scheme Programming 0 July 3, 2015 03:53
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
mesh problem and looking for udf sine wave'case wanghong FLUENT 0 March 22, 2005 20:43
