WLF shift function - Ansys
Old   March 13, 2018, 11:29
Default WLF shift function - Ansys
Samuel
samuel_ is on a distinguished road
I have the datas of 7 relaxation tests at 7 different temperatures (the names of the files are T0.txt, T1.txt .... T6.txt) where T0=250.65K is the reference temperature for the WLF shift function.
I want to calculate the values of the constants (C1 and C2) in the WLF shift function. To do that I followed this tutorial : https://www.sharcnet.ca/Software/Ans...tml#vmcftable1 (section 6.2. Viscoelastic Material Curve Fitting). However, I obtain bad results (negatives constants and bad fitting of the shift function) and when I change just one line on my code the results change a lot.
Here is my code :
/prep7
tbft,eadd,1,sdec,T0,txt
tbft,eadd,1,sdec,T1,txt
tbft,eadd,1,sdec,T2,txt
tbft,eadd,1,sdec,T3,txt
tbft,eadd,1,sdec,T4,txt
tbft,eadd,1,sdec,T5,txt
tbft,eadd,1,sdec,T6,txt
tbft,fcase,1,NEW,PVHE,fit_WLF
tbft,fadd,1,VISCO,pshear,3
tbft,fadd,1,VISCO,pbulk,3
tbft,fadd,1,VISCO,shift,wlf
tbft,fcase,1,FINI
tbft,set,1,CASE,fit_WLF,,15,250.65
tbft,set,1,CASE,fit_WLF,,3,1000
tbft,set,1,CASE,fit_WLF,,5,50000
tbft,set,1,CASE,fit_WLF,,7,250000
tbft,set,1,CASE,fit_WLF,,10,1000
tbft,set,1,CASE,fit_WLF,,12,50000
tbft,set,1,CASE,fit_WLF,,14,250000
tbft,fix,1,CASE,fit_WLF,,15,1
!tbft,set,1,visco,temp,,tdep,1
tbft,set,1,case,fit_WLF,,comp,pshear
tbft,set,1,case,fit_WLF,,tref,250.65
tbft,solve,1,CASE,fit_WLF,,1,10000,0.0001,0.0001
tbft,set,1,case,fit_WLF,,comp,pbulk
tbft,set,1,case,fit_WLF,,comp,pvhe
tbft,set,1,case,fit_WLF,,tref,253.15
tbft,set,1,case,fit_WLF,,tref,255.65
tbft,set,1,case,fit_WLF,,tref,263.15
tbft,set,1,case,fit_WLF,,tref,273.15
tbft,set,1,case,fit_WLF,,tref,283.15
tbft,set,1,case,fit_WLF,,tref,298.15
!tbft,set,1,case,fit_WLF,,tref,250.65
!tbft,set,1,CASE,fit_WLF,,comp,
!tbft,solve,1,CASE,fit_WLF,,1,10000,0.0001,0.0001
tbft,fset,1,CASE,fit_WLF
If someone can help me, it would be very nice
samuel_ is offline   Reply With Quote
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
