January 5, 2018, 07:30 |
Ground effect problems(Ahmed body)
Denis Ramon
Rep Power: 8 |
Hello everbody,
I'm simulating a Ahmed body... Firstly i did a transient simulation, with the following BC: -Ahmed surface -> Wall -Inlet -> Velocity-inlet (40m/s) -Outlet-> Pressure-outlet -Road -> Wall -Symmetry Plane-> Symmetry -Top -> Wall Firstly I used a k-e model, after I changed to k-omega, and in both case everything was good, low rediduals, Cd and Cl converges and etc... After I tried to consider the ground effect. I changed the Road bondary condition to wall moving (I considered the same inlet speed 40m/s). When I used k-e model everything was right...But using k-omege model the solution never converges, Cl and Cd gets a ocilatory behavior... Anybody knows how could I make the K-omega model works considering ground effect? |
ahmed body |
How to calculate effect of force on single joint 2 body system | quarkz | Main CFD Forum | 6 | March 12, 2016 19:43 |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 07:26 |
Ground Effect | sudheesh | ANSYS | 1 | February 17, 2014 01:30 |
Ground Effect | sudheesh | Main CFD Forum | 2 | January 28, 2014 18:17 |
Body in windtunnel - high preassure behind the body? | Andyjoe | OpenFOAM | 4 | February 16, 2010 10:57 |
