January 5, 2018, 08:15 |
Wind Tunnel Analysis
Ersan
Hi everyone,
I'm trying to analyze a wind tunnel by using ANSYS 16. A few days ago, I added a cavity on the tunnel and tried to analyze the system again and I faced some problems. My solution is pressure-based, with Transition SST method. My problems are: 1. "turbulent viscosity limited to viscosity ratio of xxx in xxx cells" 2. "temperature limited to xxx in xxx cells" 3. I tried to use different methods like Standart k-omega method but the solution diverged. I also tried to edit my grid and it currently looks like the picture below. I made some research and saw that my problem migth occur because of poor meshing. I adopted my grid on Fluent but that didn't solve my issue. Some said that it can happen because of boundry conditions. I used the same boundary conditions before I added the cavity. |
cavity flow, cfd, fluent, wind tunnel |
how to setup 3d wind tunnel | bukm | Siemens | 9 | December 13, 2014 16:06 |
Meshing Wind Tunnel | Nazo | FLUENT | 0 | October 18, 2007 11:24 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 18:33 |
CFD v.s wind tunnel in airfoil | FRED CHEN | CFX | 0 | July 12, 2005 03:59 |
wind tunnel correction | Arthur Chen | Main CFD Forum | 2 | September 4, 1998 19:42 |
