Orient Mesh along local coordinate System
Old   December 13, 2017, 06:14
Default Orient Mesh along local coordinate System
Dog92 is on a distinguished road
i want to orient my mesh along an axis of my local coordinate system. This feature is stated in the manual. I am using an Octree mesh and did the necessary settings. I enabled the option in Global Mesh Setup >Volume Meshing Parameters >Use active local coordinate system and the local coordinate system is active but the mesh has always the same orientation. I even flipped the axes. Do you have an idea ?
Thanks.
Dog92 is offline   Reply With Quote
Old   December 15, 2017, 05:11
ok i got it now. I have a rotational periodic body and its important that the axis for the periodicity is the same axis of the local coordinate system
icem, local coordinate system, mesh, orient
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
Unstructrued O-type Mesh of a cylinder with icoFoam kindle OpenFOAM Running, Solving & CFD 1 December 2, 2016 12:45
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
