Need a suggestion for a good machine to simulate FSI problems |
December 12, 2017, 13:22 |
Rep Power: 8 |
Dear All,
I have a fluid-structure interaction problem dealing with big deformation in the structural part. My current machine is an Intel Core i7 with 3.60GHz velocity and 32 GB RAM, which I think is a good machine. But, it take too much time to run a 2 seconds run, almost 24 hours. Is it related to writting outputs, which I may need a SSD hard drive to accelerate that? Structural mesh has about 5000 elements and Fluent part has around 300,000 elements. I don not want to reduce number of elements. I do have a grant to buy another machine, so what do you think is better to get? Regards, Malekan |
December 12, 2017, 19:36 |
Rep Power: 10 |
If writing output is the problem, an SSD would not really solve your problem. While an SSD is usually much faster than an HDD, it is still much much slower than the RAM.
Have you tried running the same simulation without any output before the end time? |
December 13, 2017, 07:58 |
Thanks
Rep Power: 8 |
Dear MakisH,
Thanks for your comment. I will try to run the problem without any output until the end time, to see what I can get! Regards, Malekan |
ansys 18.2, fluent, fluid structure, transient structural |
FSI Two-Way Problems | Abduri | CFX | 6 | February 3, 2009 23:41 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
What is weakstrong coupling in FSI problems | hajo | OpenFOAM Running, Solving & CFD | 5 | May 15, 2008 01:45 |
good textbook incl lots of solved problems | another_newbe | Main CFD Forum | 2 | November 29, 2005 13:20 |
PC vs. Workstation | Tim Franke | Main CFD Forum | 5 | September 29, 1999 15:01 |
