fluent Solution
Old   December 11, 2017, 10:42
Thumbs up fluent Solution
Ishan Sharma
ishaniis is on a distinguished road
I am currently doing a project whereupon
I need to develop a vaporizer whose
Pipe
OD - 30mm
ID - 28mm
t = 1mm
Pressure(Inlet) = 3.5 Pa
Pressure (Outlet) = 1.5 Pa
Mass flow rate = 3g/sec = 0.003 kg/sec
Inlet Conditions (Fluid) - 25 degree celsius
Outlet Conditions (Fluid) - 95 degree celsius
L (Pipe)= 450mm
I have calculated the Q for the given problem by the formula
Q = m. Cp . (dT)
Correspondingly, Heat Flux by (Q/A)
I want to simulate it for a pipe which will be provided heating by wounding Nichrome wire as a Heat source, the entering fluid must vaporize at the outlet of the pipe section
Now ,
Q1. I am little confused to keep the wall boundary conditions
as -
Constant Heat flux
or
Constant Wall Temperature
or
Convection.
Q2. Can I find out the percentage of fluid which is converted into vapour form?
ishaniis is offline   Reply With Quote
ansys 14.0, fluent
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 1 June 28, 2024 08:03
Water-Salt Solution - FLUENT CSolarFD FLUENT 6 July 31, 2017 09:58
Exporting fluent solution Je5u5 FLUENT 0 June 7, 2016 06:07
Turning off equations during solution in CFX, like fluent. adilsyyed CFX 3 April 27, 2015 04:57
One-way FSI... can I start with structure and then transfer solution to Fluent YANNAPOL FLUENT 1 April 1, 2015 16:52
