December 7, 2017, 20:31 |
Steady-State Thermal vs Transient thermal
Marco Reyes
Hi everybody:
I have a question: What are the differences between the operation Steady-State Thermal and the Transient Thermal analyses? I know that in terms of math, a steady state means a magnitude which does not vary with time, but after taking a look at both analyses using Workbench, I noticed that in both cases it is possible to generate animations and specify time conditions. I do not completely understand why should I use one or another in a particular case where I have constant loads but a varying temperature field. Thanks |
thermal analysis |
Importing solution from thermal steady state analysis to transient analysis | david_1995 | ANSYS | 0 | July 31, 2017 06:54 |
DPM steady state or transient | Danial1992 | FLUENT | 0 | June 25, 2017 20:30 |
Moddeling solid settlement in water tank steady state or transient? | 88phil88 | CFX | 1 | March 9, 2011 19:45 |
Steady state > Transient | Willem | FLUENT | 1 | June 24, 2008 12:18 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 15:37 |
