Unexpected stop of periodic simulation
Old   December 1, 2017, 09:23
Default Unexpected stop of periodic simulation
Edemar
Edemar is on a distinguished road
I am simulating the temperature field in a satellite. The simulation is transient, but all the boundary conditions are periodic. I wish to let the simulation running for some cycles until the periodic result is obtained. The criteria to stop is 20 full cycles. However, the simulation stops in the middle of the fifth cycle. I have simulated two cases with different orbital parameters and both have stopped in the same iteration number 5502, in the middle of the fifth cycle.
The error is #004100018 has occurred in subroutine FINMES. Fatal overflow in linear solver.
I checked the residuals and imbalance. Both are very low. I checked all the expressions in the boundary conditions and they are correct. I have tried two refinement of meshes but it didnt help. I have used two timestep,1s and 5s, but didnt work either. In fact, doesnt matter the size of mesh or timestep, the simulation crashes always at the same physical time.
I dont understand the problem because in the first 4 cycles the simulations runs properly. On the other hand, some cases with different spins (a parameter of the satellite) didnt crashed.
Edemar is offline   Reply With Quote
error #004100018, periodic bc, stop abnormally, transient analisys
Stop Openfoam simulation deji OpenFOAM Running, Solving & CFD 12 August 25, 2020 12:33
3D Periodic Boundary in SU2 jywang SU2 1 May 1, 2018 21:43
Unexpected CFX_SOLVER license error in ANSYS-CFX FSI Simulation PranjalNewton CFX 10 April 13, 2018 11:43
[ICEM] Periodic condition between ICEM and FLUENT Touré ANSYS Meshing & Geometry 0 August 5, 2012 18:00
solution divergence in periodic simulation aqstax FLUENT 1 February 27, 2012 02:50
