Heated Panel onto Heat Pipes cooled by water pipe |
November 20, 2017, 15:26 |
I need to model the following experiment:
* A Heated Panel, which includes several different material layers, * 9 parallel Heat Pipes at its backside * with a Water Pipe passing through all of the condensers in series * water is provided by a closed system, including a water tank. The experiment ends once the water tank has reached 45Celcious(3-4hours in 30s timesteps) What strategy shall I use to model this experiment ? Bare in mind that the HEAT PIPES are the focus of the study. Shall I use: * ICEPAK for the plate then import the data onto * FLUENT for the heat pipes + water pipe ? That wouldn't work because the two systems affect each other. Is ICEPAK even necessary ? |
fluent, heat pipe, plate heat exchanger |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 15:27 |
Vertical Pipe water flow | Goutam | FLUENT | 0 | April 30, 2014 09:25 |
help needed : 2d water flow in heated pipe | abuabdellah.albatal | FLUENT | 6 | May 4, 2012 04:10 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 08:10 |
