Ansys ACP Solid Model of CFRP Wheel Laminate
Old   October 31, 2017, 13:44
Default Ansys ACP Solid Model of CFRP Wheel Laminate
Marc
marccolome is on a distinguished road
I'm attempting to use ACP to simulate loads on a FSAE CFRP Wheel.
The problem I have is that I'm unable to "butt-joint" the mesh from different stackups, as written in the documentation of the software (inside solid model options)
This model represents a 10" monolithic Wheel Shell in CFRP (CAD from UG 11). Mesh is very large (3mm) because of the computational power of my computer. I have run the same model in a rack system with 0.6mm mesh with the same (bad) results. But mesh quality might be a problem (not about the size of mesh in ANSYS but the mesher? I will try to mesh it on ANSA but my colleague is out of the workshop for some days).
As you can see in the attachements, the laminate is:
1. First a "A" thickness on a "name selection" which is the full surface.
2. Second the "A" thickeness on every "name selection" which is every part surface.
So regarding my question, how do you do in ANSYS ACP butt-joining plies?
Note: Under NX I have not part any surface.
marccolome is offline   Reply With Quote
acp (pre)
[ANSYS Meshing] How to use solid elements for compositesin ansys ACP? rajsundarkj ANSYS Meshing & Geometry 0 February 22, 2017 02:41
turubelnce model in ansys fluent sa har FLUENT 3 February 16, 2016 10:19
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Solid model becoming surface while importing into ansys... ravindra889 ANSYS 2 February 26, 2015 02:16
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
