October 2, 2017, 19:41 |
Cutting force Analysis of blade
Kinnon Pang
Hi everyone,
I have never really used ANSYS before, but I have now have to design a blade that needs to cut through 20mm reinforced bar (the metal rods used in concrete beams). I was going to attempt to analyse it by hand but my supervisors said that it would be much too complex, and that ANSYS would be a much easier. The movement of the blades act like a pair of scissors; with one blade stationary and the other rotating about a pivot. I need to know the stresses and forces that the blade will experience when it cuts through the reinforced bar. Also a simulation that has a time step so that I know where and how large the forces are as the blades turn. Photos of the cutting mechanism is in the following link: http://ansysforum.com/topic/30359907/1/ |
ansys, blades, cutting, rebar, simulation |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
Flutter analysis of compressor blade | sridharabc228 | CFX | 1 | April 13, 2017 19:10 |
Rotating blade analysis | acalado | STAR-CCM+ | 1 | December 19, 2016 14:34 |
Wind Turbine blade analysis using Fluent | aloshjames | FLUENT | 0 | May 5, 2014 01:15 |
Help Required on CFD for Turbine Blade Analysis | kkjj2008 | Main CFD Forum | 5 | July 9, 2009 15:41 |
