September 25, 2017, 00:49 |
Generating enclosure error
Thusitha prasad
There is a error message while generating the enclosure as
" Error: Operation would result in non-manifold bodies Context: Geometry Engine, while generating Feature Enclosure1 " how can i solve this problem? |
September 25, 2017, 02:48 |
Gwenael H.
Rep Power: 20 |
Hi Thusitha,
Can you post a picture of the geometry you want to create an enclosure from? If you’re working with an intricate part or facetted geometry you may need to smooth it before trying to extract an enclosure |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
