Workbench [18.0] import Design Points from Excel file |
August 18, 2017, 17:56 |
Hello Ansys suite experts,
I want to run calculations of 2D airfoil for a range of angles of attack. I got to the point that my mesh and solver settings in CFX provide good results for a sample AOA. I am able to set up design points wih parametrised velocity vector, however I have to input the manually. I found a way to import an Excel spreadsheet and load separate parameters with one given value but I was unable to find a way to import an array of values representing all the design points. Does anybody know if this is possible? Thank you for your answers. |
airfoil 2d, ansys 18.0, cfx, workbench |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 04:04 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 12:32 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
