August 8, 2017, 13:05 |
[ANSYS 18.0] Application failed to connect
#1 | ||
Hello everyone,
I've been using Ansys for some time now. I had no problems to make my simulations using CFX and everything was fine. But one day, I wanted to use CFX, I opened my project and when I wanted to edit CFX-pre, the workbench displayed the following message: Quote:
http://www.esss.com.br/suportecae/in...es/Page592.htm I tried what was suggested but it didn't worked. I also tried to run CFX without using Workbench, I god the following messages: Quote:
So I tried to reinstall ansys 18.0 again, didn't worked... I think this is because of a recent update of Windows 10 but I'm not 100% sure. Do you have any solution or do you know how to reset completly every Ansys parameters? Than you in advance |
August 12, 2017, 17:42 |
UPDATE:
After reinitializing my whole PC , CFX is working again . It seems that the problem came from some corrupted files (.dll I guess) which were removed with the reinitialization. |
October 11, 2018, 01:47 |
hi
jini
Rep Power: 10 |
Hi Makard! I have faced same problem. how did you threat it?
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 04:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 16:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 10:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
