Difference in results with different "Processing options" (Core)
Old   July 17, 2017, 14:34
Question Difference in results with different "Processing options" (Core)
Ferdinand Allmendinger
Elmo11 is on a distinguished road
Hey,
I have been searching the Net for a couple hours, but didn't find anything about this.
So when I use Fluent with the totally same settings but different core settings (Serial/Parallel with 1, 2, 4, 6 or 8 Cores) I never get the same results. Sometimes the residuals converge, diverge or just stay constant. I'm not sure if this is a problem or which settings I should trust. If I use the same core settings the results are also nearly (95%) the same.
I have an Core I7 with 4 cores and HT but it doesn't matter. This problem also occur on different PCs with different meshes (last pic with 12 cores).
E.g.
1 Core (Serial)
2 Cores (Parallel)
4 Cores (Parallel)
8 Cores (Parallel)
Again with 8 Cores (Parallel)
12 Cores (Parallel)
Please I need help with this. Maybe someone had an explanation or a solution for this phenomenon...
Elmo11 is offline   Reply With Quote
core, parallel calculation, serial parallel multicore
mpirun, best parameters pablodecastillo Hardware 18 November 10, 2016 13:36
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
difference in results between 2D and 3D Michelle CFX 3 December 10, 2007 02:59
Difference results between Steady and Unsteady? Giang T Vu FLUENT 6 May 22, 2004 07:37
Difference in results using different Mesh? Julie FLUENT 7 July 2, 2002 11:28
