Icepak - block using 2-resistor network
Old   July 11, 2017, 18:15
Exclamation Icepak - block using 2-resistor network
John Smith
thermal12345 is on a distinguished road
Hello All,
This question is for ANSYS ICEPAK. I had a question regarding the temperatures I get using a 2-resistor network within a block and assigning some power at the junction. Once it is done running, I get some temperatures at the junction and the two sides that had the resistances applied.
My question is that the temperatures do not follow the resistance network, why is that? For example, I should be able to back calculate the junction temperature by using the temperatures from either side and the corresponding resistances, or at least get within the ballpark. My temperatures do not follow this logic and I cannot trust my results.
thermal12345 is offline   Reply With Quote
ansys, ansys icepak, electronics cooling, icepak
[ICEM] Merge sheet with free block in ICEM sagarmore ANSYS Meshing & Geometry 1 November 22, 2021 14:29
Icepak - source vs. block with power dissipation Bigfoot ANSYS 0 June 29, 2016 18:12
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 17:37
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 11:01
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
