Save Results automatically by APDL Command
Old   July 4, 2017, 09:14
Default Save Results automatically by APDL Command
ansyxyz is on a distinguished road
I run a parameterized simulation and I would like to save the results after the harmonic analysis of each Design Point as a table in an Excel file. The result parameters, which I want to export, are "frequency", "amplitude" and "phase angle". They are already shown in Ansys Workbench as a frequency diagram and also as a table (see attachment).
The name of the file to be saved should contain the current date and time or a number with iteration, otherwise the results of the parametric study would always overwrite itself.
I have already written a code, but I have following problems:
- I defined a fixed Node by it’s ID (here: 179778;see attachment) to get the results “amplitude” and “phase”. But I would like to get the results for a variable point, which should be defined before by a name.
- Moreover, I am not sure whether the code for the iteration of the name of the file is correct.
/title, threedof.inp, three dof vibration class model
! ***************** output frequencies *******************
/post1
/output,threedof,frq ! write out frequency list to ascii file .frq
set,list
/output,term ! returns output to terminal
!***************** output eigenvectors *********************
!define nodes for output
allsel
/output,threedof,eig ! write out eigenvectors to ascii file .eig
*do,i,1,3
set,,i
prdisp
*enddo
/output,term
/post26
threedof,,rfrq ! frequency response results
xvar,0 ! display versus frequency
lines,1000 ! specifies the length of a printed page for frequency response listing
Test1=179778 ! node ID of the point, where the force is applied
nsol,2,Test1,u,y,duy ! specifies nodal data to be stored in results file
! u - displacement, y direction
! note that nsol,1 is frequency vector
*dim,my_path,string,80
my_path(1) = 'c:\meinpfadzurdatei\''
*dim,iter_file_path,string,80
iter_file_path(1) = strcat(my_path(1),'my_iteration_file')
*vread,warten(1,1),%iter_file_path(1)%,'txt'
(f2.0)
/output,'threedof',chrval(warten(1,1)),dat
prcplx,1 ! stores phase angle in asci file .dat
prvar,2,3
/output,tmp
*dim,warten,array,1,1,1,,
warten(1,1) = warten(1,1)+1 ! increase iterator
*cfopen,strcat(my_path(1),'my_iteration_file'),'tx t'
*vwrite,1
(f2.0)
*cfclose
ansyxyz is offline   Reply With Quote
Old   June 5, 2018, 09:16
Nick Verhoeven
0ldnick is on a distinguished road
same question over here. Anybody knows the answer? I want to export automatically the frequency response for several nodal points.
0ldnick is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
How to save macro results in the output file? Peggy FLUENT 0 May 21, 2007 04:36
Help! How i save in a .txt some results? Toni Cominceanu Main CFD Forum 0 May 11, 2005 20:21
COMMAND -Multi-plot&store data sam FLUENT 0 August 22, 2002 04:59
