Icepak fluid meshing
Old   June 5, 2017, 05:35
Default Icepak fluid meshing
Amir
amir2276 is on a distinguished road
Hi friends,
I have a problem in meshing a cooling system for an electronic device. It is a water cooling system in which the water flows through the fins and cools down the baseplate of a power module. I use a cubic block that surround all the fins in the heatsink and define it as a fluid. I have learned that if I give it a lower priority compared to the solid objects, the Icepak can separate it from the solid parts, but Icepak cannot mesh it at all. I imported the heatsink as a CAD object but I even tried to simplify it as the basic Icepak objects in the Designmodeler but it does not work. Do you have any solution? Thanks in advance.
amir2276 is offline   Reply With Quote
fluid, geometry, icepak, mesh, meshing
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
[ANSYS Meshing] Need help in meshing complex fluid domain Dinesh_Dhande ANSYS Meshing & Geometry 6 January 18, 2017 04:39
2D selective mesh generation Durga Sravan ANSYS 17 February 5, 2014 01:56
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 10:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
