DO Loop in APDL
Old   May 23, 2017, 13:48
Smile DO Loop in APDL
Claas
keulehans is on a distinguished road
Hey Guys,
I have to do a parametric study in ANSYS, where I have to investigate the influence of the dimensions of a rectangular plate with tensile forces. Therefore I have a couple of hundred working models (as .inp files) of the plate with each of them having slightly different dimensions.
The input files are called:
ANSYS_MODEL_1
ANSYS_MODEL_2
ANSYS_MODEL_3
.... and so on.
My problem now is, that I am not able to write a working Batch Code in APDL, so that ANSYS calculates all models consecutively.
I tried the following code:
*DO,i,1,521,1
valchr(i)
/input,ANSYS_MODEL_i,inp
/solu
outpr,basic,all
irlf,-1
/output,mass_output,txt
psolve,elform
psolve,elprep
/output
finish
ANALYSIS_MODE = 'LINEAR_STATIC'
/solu
allsel,all
/TITLE,ANALYSIS_MODE
ANTYPE,STATIC
PSTRES,ON
SOLVE
fini
/post1
/EOF
*ENDDO
/EXIT,ALL
With this code however,Ansys always searches for an input file, which is called "ANSYS_MODEL_i" instead of putting the right number of the DO Loop for the i.
Doea anybody know how to do it properly?
And am I using the DO Loop right?
Thanks a lot in advance, I really am desperate by now
Cheers
keulehans is offline   Reply With Quote
Old   May 24, 2017, 03:04
Tushar
S.Tushar is on a distinguished road
You are parsing the file name as a character string. I don't think 'i' will iterate with passes of the *DO loop.
when you write /input, filename_i, APDL searches for a file with name filename_i in the current directory.
There are many ways to achieve the parametric iterations that you are aiming at, maybe use the LINE or LABEL parameter of /input to read input lines from same input file.
cheers
S.Tushar is offline   Reply With Quote
Old   May 27, 2017, 08:18
Claas
Thanks for your reply first of all. I asked my supervisor about changing the input files, but I am not allowed to do so.
He made it clear, that my task is, to write a batch code, which consecutively calculates all the models and saves each results file, so he can look at those later.
My current code looks like this:
*DO,i,1,521,1
/input,'ANSYS_MODEL_' chrval(i),inp
/solu
outpr,basic,all
irlf,-1
psolve,elform
psolve,elprep
/output
finish
/solu
allsel,all
ANTYPE,STATIC
PSTRES,ON
SOLVE
fini
/post1
*DIM,DP_DISPL_ARRAY,ARRAY,5,1
ALLSEL,ALL
Nn = 202876
*GET,Xcord,NODE,Nn,LOC,X
*GET,Ycord,NODE,Nn,LOC,Y
*GET,Zcord,NODE,Nn,LOC,Z
*GET,U_X,NODE,Nn,U,X
*GET,U_Y,NODE,Nn,U,Y
DP_DISPL_ARRAY(1,1)=Xcord
DP_DISPL_ARRAY(2,1)=Ycord
DP_DISPL_ARRAY(3,1)=Zcord
DP_DISPL_ARRAY(4,1)=U_X
DP_DISPL_ARRAY(5,1)=U_Y
! write array to file
RST_DP_U_OUTPUT_ARRAY='DP_DISPL_ARRAY'
RST_DP_U_FILE_NAME=STRCAT('RST_U_DP_',CHRVAL(1))
RST_DP_U_FILE_EXTENSION='dat'
writecsv,RST_DP_U_FILE_NAME,RST_DP_U_FILE_EXTENSIO N,RST_DP_U_OUTPUT_ARRAY
allsel,all
/EOF
*ENDDO
/EXIT,ALL
This however gives me the error. Invalid /INPUT file or too many levels.
Can you help me with this?
Thanks in advance!
Cheers
ansys, apdl, do loop, valchr
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
