raunak jung pandey
Rep Power: 10 ![]() |
Hello everyone
I am a user of CFX. I need to use Fluent for some problem.I have a question regarding the difference in initialization in CFX and FLUENT. What settings need to be used so that both fluent has same initialization as CFX. Thank You Thank You |
Svetlana Tkachenko
Rep Power: 14 ![]() |
In CFX-Pre, this is a 'initialization' tab under your domain. In Fluent, this is 'solution initialization' section at the left tree. Select 'standard initialization' in Fluent and specify the same values by hand as what you have in CFX. Please tell whether this is sufficient for your problem or not.
cfx, cfx & fluent, fluent |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 08:08 |
Comparison of fluent and CFX for turbomachinery | Far | CFX | 52 | December 26, 2014 18:11 |
Different result in CFX and fluent for mass trans.? is segregated better? | ftab | CFX | 7 | September 27, 2012 07:57 |
CFX or Fluent for Turbo machinery ? | Far | FLUENT | 3 | May 27, 2011 03:02 |
Fluent Vs CFX, density and pressure | Omer | CFX | 9 | June 28, 2007 04:13 |
