the problem using the UDF for low-Reynolds-number turbulent model |
May 19, 2017, 03:04 |
Rep Power: 11 |
I wrote the LB low-Reynolds-number turbulent model using the UDF and implemented into Fluent 14.0. But the results of k and e were negative in the near wall region.
is there anyone with the same problem? |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
turbulent flow in cavity problem using k-w model | khairy | Main CFD Forum | 3 | February 27, 2005 13:12 |
