Using inlet mpi in parallel ANSYS fluent with AMD processors
Old   May 10, 2017, 09:36
Talking Using intel mpi in parallel ANSYS fluent with AMD processors
meisam
freebird is on a distinguished road
Hi
I set up and use successfully this tutorial (https://goo.gl/Ww6bkM) for clustering 2 machine to run the ansys fluent 17.2 in parallel mode. machine 1 (node1) is win server 2012 R2 64bit and machine 2 (node2) is win 8 64bit. both of them use Intel core i3 3.10 GHZ and 8GB memory. this tutorial use intel mpi for paralleling.
Know i set it up for 2 machine with same OS like above, but with quad core AMD opteron processor 2378 2.4GHZ and 16 GB memory.
When i run for parallel processing according the tutorial this error appear.
Is it possible that intel mpi dont compatible with this AMD processors for parallel run or other reason has been caused this? what should i do?
thanks.
freebird is offline   Reply With Quote
Old   June 16, 2017, 10:04
meisam
I find it. i changed all OS to win 8.1 and it was solved.
ansys, cluster computing, intel mpi, parallel fluent launch
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 12:58
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
Fluent PARALLEL & MPI Luca FLUENT 0 May 13, 2006 04:04
