CFX - Bingham Model with yield stess variable with temperature |
April 21, 2017, 13:54 |
Anna Carolina Gomes da Costa
Hello, I am trying to simulate a parafin deposition model using CFX. In order to facilitate my job I am trying to apply a bingham behaviour for the viscosity of my fluid with yield stress as a function of temperature. I dont think i can use an expression for the yield stress so now I am thinking about creating an expression for my viscosity. So I have 2 questions:
1) I would like to calculate the sheer stress in my fluid. There is not a variable for that in cfx. There is one for sheer strain rate but the relationship between the two is quite complicated for my flow. its a flow in a annular section with different temperatures in the inner and outter walls. Has here tried something similar? (2) what kind of numerical issues might appear because of this model? Anyways, I am having a hard time figuiring out a solution for this. I am a grad student, havent used CFX for a long time, pretty new to it. Thank in advance, ANNA |
July 16, 2019, 17:26 |
#2 | |
Sebastian
Rep Power: 7 |
hi could you solve your problem i am working in a plastic bingham and i do not know much |
bingham, cfx, shear stress, shear stress equations, viscosity |
"Double slope" Bingham viscosity model | TemC | OpenFOAM Programming & Development | 13 | April 18, 2017 05:20 |
Difference between Fluent transitional model and CFX transitional model | Anna Tian | FLUENT | 2 | August 7, 2014 11:52 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 23:04 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
