Ansys Acoustics
Old   April 12, 2017, 14:27
Unhappy Ansys Acoustics
Phil McCrackin
narthurm is on a distinguished road
I am having problems importing and mapping a three-dimensional temperature field onto a Modal Analysis (with acoustics module) problem. I have explored the "external data" feature, but it does not allow for connection to the setup block of the modal analysis. There is the "acoustic imported temperature" option within Mechanical but I am not able to properly import and observe my ascii file (perhaps the file is oriented incorrectly).
Any help or suggestions are appreciated
narthurm is offline   Reply With Quote
Old   April 13, 2017, 03:46
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Phil,
You should use the “imported temperature” of the acoustic module under loads. You can either have a .txt or .csv file. The structure should be X Y Z T (m m m C) and it needs to be oriented in with the same global CS of your current system.
Have fun
Gweher is offline   Reply With Quote
ansys acoustics, mapping, spatial field
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 13:11
[ANSYS Meshing] ANSYS mesh - I was surprised... assafwei ANSYS Meshing & Geometry 0 September 4, 2014 13:17
Ansys HPC licensing policy assafwei ANSYS 0 June 29, 2014 17:00
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 11:28
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
