How to convert pressure-inlet to velocity-inlet? |
April 9, 2017, 11:41 |
FeiTeng
Rep Power: 9 |
Hi all
I have a question about how can I convert the pressure-inlet to velocity-inlet. I did a simulation on a compressor balde using CFX, and the inlet boundary conditions were 'Total Pressure','Total temprature' and 'flow angle'. The result was quite good. But now I want to use velocity-inlet instead of pressure-inlet. So I extract velocity components from pressure-inlet case, and then impose the velocity components to velocity-inlet case. The static pressure at outlet are the same. Unfortunately, I can not get the same result. From the monitor, I found that the total pressure are quite large at the inlet. Can anybody explain the reason?????? Thanks a lot |
April 29, 2017, 00:31 |
Lucky
Rep Power: 66 |
You also should extract the static temperature and apply this at the inlet.
boundary condition, cfx & fluent |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 18:16 |
Pressure inlet vs outlet position, transient, time dependent pressure and gravity | silent2608 | FLUENT | 0 | February 6, 2016 11:19 |
Pressure loss Velocity coupling | CFXMUFFIN | CFX | 1 | February 6, 2016 05:43 |
Set inlet velocity and pressure in cavitational model | GerardX89 | FLUENT | 1 | July 5, 2012 17:17 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
