How to curve fit the Ogden Foam 3rd Order model?
Old   April 4, 2017, 14:51
Default How to curve fit the Ogden Foam 3rd Order model?
Lucas Ribeiro
Warlord is on a distinguished road
Hello folks,
I have a quasi-static compression curve for a material and would like to use the Ogden Foam 3rd Order hyperelastic model implemented in Ansys. Does anyone know how to curve fit it? This model has 9 params and I don't know how to find them.
If I were to use the Ogden 3rd Order (not the foam one) it would be ok, since it’s just a matter of creating a new material in the Engineering Data toolbox (workbench), use the Uniaxial Compression Test Data as a new material property, then drag the Ogden 3rd Order and realise over this new property. At this point a “Curve fitting” option appears. The same option does not appear for Ogden Foam 3rd Order model. Did somebody use this material before?
Ps.: Using Ansys 17.1
Thanks
Warlord is offline   Reply With Quote
ansys, curve fit, ogden foam 3rd order
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
