March 27, 2017, 14:41 |
Solver Stuck in ANSYS Aqwa WB 14.5
Rehan Jamshed
Rep Power: 9 |
Hi Everybody,
I want to model RIGID BODY oscillations of a box-like vessel in ANSYS AQWA WB14.5. The vessel is floating in CALM WATER. I want to simulate RADIATION and obtain the following: Hydrodynamic Damping Coeff Added Mass Coeff I know that these two are obtained as Curve Plots where on x-axis is Encountered Frequencies. I started with simple Cylinder Model as found from a Tutorial. The program returns Error as " ...Solver Aborted..." Any help will be appreciated. Best regards, RJ Khan |
aqwa, radiation |
2-way FSI in Ansys CFX 15 | LucasGasparino | CFX | 3 | August 6, 2015 03:17 |
ANSYS 14.5: overflow ANSYS 15: works just fine | Peacekeeper | ANSYS | 0 | July 15, 2015 13:29 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
ansys cfx solver exit with return code 1!!!!! | mhabibnia | CFX | 7 | August 19, 2013 03:53 |
ansys 14.5 comparability with OS | Raj14 | CFX | 2 | February 5, 2013 23:56 |
