Rep Power: 0 ![]() |
Hi all,
I'm trying to run a two way coupled FSI using Fluent and APDL on a cluster, via a batch file. The systems run succesfuly serparately and I am able to set up the system coupling serverice. Unfortunately once both participants are connected I receive the error 'Exception encountered when the coupling service requested | | ChartableData->GetRootLevelName: Communication socket | | unexpectedly disconnected. ' I understand this is due to licensing issues, and that I need to specify a separate license. I am aware of how to do this on Workbench but have been unable to find any documentation about how to do this via the command line. The cluster runs linux. I believe my license preferences are Academic Research. I've attached my batch file for reference, although I believe it is correct if not a bit untidy. I don't suppose anyone could provide any insight? Many thanks |
Rep Power: 10 ![]() |
Hi Calumn,
Did you manage to solve this issue? Also, did you manage to run 2-way FSI via command line in Windows? would you be kind to share your batch code? Thanks, |
batch, fsi, license |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
