Difference between inlet values and calculated values
Old   March 20, 2017, 11:32
Unhappy Difference between inlet values and calculated values
Laura
Lauralo_14 is on a distinguished road
Hi everyone!
I'm trying to simulate air throught a Combustion Chamber with ANSYS AIM, so let's say that I have a cylinder with holes: multiple inlets but only one outlet.
I have calculated the flow rate throught each hole and the main inlet so I use the flow rate as my boundary at inlet. For continuity purposes I set the outlet as the sumatory flow rate.
The problem is that in the solutions window, when I check each inlet the flow rate is "wrong": for example I set 3 kg/s and the calculated value is 0,03 kg/s
Does anyone knows what I'm doing wrong? THANKS A LOT
Lauralo_14 is offline   Reply With Quote
ansys, calculated, fluid flow, solution error
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
High pressure values at inlet and Loss of Mass flow at AMIs -- pimpleDymFoam coolcrasher OpenFOAM Running, Solving & CFD 3 April 18, 2016 03:51
CFD Post: Difference between calculated surface values using different methods Shawn_A CFX 11 July 30, 2013 14:07
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong jannnesss CFX 5 February 25, 2011 17:24
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
