large eddy simulation(LES) for turbomachinary |
March 7, 2017, 03:28 |
FeiTeng
Rep Power: 9 |
Hi all
I have a question for using LES in a turbomachinary. Normally, we impose "Total Pressure","Total Temprature" and "Flow Angle" as inlet boundary conditions (subsonic). So , if I impose these as inlet boundary conditions, how could I impose velocity fluctuations at inlet ? May I give some fluctuations on Total Pressure or Total Temprature ?? Can anyone gime me the answer or some recommendation? |
March 7, 2017, 09:35 |
Uwe Pilz
Rep Power: 15 |
An easy to implement an obvious way ist to calculate small timesteps and modify the U file in the latestTime dir. Your controldict.startFrom should contain "latestTime".
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 13, 2017, 01:17 |
FeiTeng
Rep Power: 9 |
Thank you for your answers ! But sorry, I don't quite understand. Could you please make it clear?
March 13, 2017, 01:38 |
Uwe Pilz
Rep Power: 15 |
If you start the simulation you have to give initial values for U and p in the 0 directory. After running the simulation for a simulated time you get results in a directory which is named by the simulated time. This contains p and U.
If you change the values to the ones you want to haveand restart the simulation, these values will be used from this simulated time on.
March 13, 2017, 08:13 |
I agree with PIU58 the problem with LES are the boundary and initial conditions. For subsonic flows you can specify velocities at the inlet, why don't tu work with velocities instead ? Nonetheless, you can follow PIU58 recommendations.
March 15, 2017, 20:41 |
FeiTeng
Rep Power: 9 |
Thank you ! I will try it.
March 15, 2017, 20:57 |
FeiTeng
Rep Power: 9 |
Sorry for late reply. In my simulation, the flow is transonic. I want to use LES method, and compare the result with the experimental data. But in the experiment, the total pressure,total temprature,and flow angle are specified at the inlet. How should I specify the inlet velocities instead ?
I can find the Mach Number distribution at the inlet from the experimental data. Can I get the velocity and static pressure distributions by using isentropic relations ? |
March 16, 2017, 01:08 |
Uwe Pilz
Rep Power: 15 |
In this case you define the pressure at the inlet and the outlet (probably 0 there). For the velocity you give the gradient: zero gradient at the outlet and the gradient according to your inflow angle for the inlet.
cfx, fluent, les |
Pressure drop in pipe flow with Large Eddy Simulation | xerox | FLUENT | 1 | October 16, 2019 09:55 |
Implicit Large Eddy Simulation Implementation | eddykendo | OpenFOAM Programming & Development | 0 | March 24, 2016 03:34 |
Large Eddy Simulation with too high Mach number | Roland R | CFX | 4 | November 25, 2010 17:43 |
Y+ range for Large Eddy simulations | Palani | FLUENT | 1 | April 5, 2007 09:49 |
AHMED BODY (LARGE EDDY SIMULATION) | Benzamia | FLUENT | 0 | February 26, 2007 05:59 |
