DES (DES,DDES,IDDES) turbulence model: Fixed or Adaptive Time step?
Old   January 31, 2017, 15:30
Default DES (DES,DDES,IDDES) turbulence model: Fixed or Adaptive Time step?
Reza Rohani
rohani is on a distinguished road
I am planning to simulate a supersonic nozzle with DES turbulence model using ANSYS FLUENT 17. I read in a FLUENT guidebook that it is necessary to use adaptive time step with DES model.
How do I choose the time step in DES model, Do I need to use fixed or adaptive time step?
It should be noted when using DES model in FLUENT, You will receive a warning message: turbulence model should only be used with the Bounded Second Order Implicit Transient Formulation. It's confusing because adaptive time step isn't selectable along with the Second Order Transient Formulation.
Knowledge is power and it can command obedience. Remember that knowledge is a ruler and wealth is its subject. The Peak of Eloquence, Saying 146
rohani is offline   Reply With Quote
des turbulence model, fluent, time stepping
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 08:56
