January 29, 2017, 23:22 |
Change settings during a simulation
Rep Power: 11 |
Hey guys,
I'm currently running an FSI simulation on 17.2. Because the simulation is complex, I've set the program to have restart points every 20 time steps. At about my 300 time step, I get an error message that says fluent has detected a negative cell volume. Thus far, changing the time step size has not solved the issue. I'd like to adjust the dynamic mesh to counteract this, but every time I try it deletes my solution files. I've got about a week of straight calculation in this, is there any way that I can change settings and troubleshoot the problem mid-simulation? Thanks in advance. |
May 31, 2017, 17:20 |
Rep Power: 11 |
To anyone still wondering about this, I finally solved it. You cannot directly change the settings within the setup of Fluent mid-simulation. You can, however, adjust certain settings within the solution.
In this particular instance, I wanted to change the dynamic mesh settings from spring-based to diffusion-based. To do this, simple double-click on the solution cell in Workbench and change the setting. You do need to need to ensure that you are on the time step that you will be restarting from. As a refresher, you check this by clicking File ->Solution Files-> Step Number you are restarting from. Hope this helps. |
June 20, 2017, 20:48 |
yardena jodeck
Rep Power: 9 |
That is true. Al changes in the setup must be perfomed from solution..
I have a question. Sometimes I need to change the mesh or add a new named surface. In that case you cant open mesh and change it ... in that case you must initialize your simulation with the older data?? (Instead of hibryd ir standard..)... or is there another way to change your mesh?? Sent from my SM-G570M using CFD Online Forum mobile app |
June 20, 2017, 20:56 |
Rep Power: 11 |
If I understand you correctly, you'd like to add new named selections to your mesh during a simulation? This, unfortunately, can't be done. While it seems simple enough, Fluent will see this as a completely new mesh. If you absolutely can't restart your simulation, try different post-processing techniques to capture what a named selection would yield, or simply make a note of it and make the change during a later revision of the simulation.
Hope this helps! |
June 20, 2017, 21:15 |
yardena jodeck
Rep Power: 9 |
I was wondering because once I realized I had forgotten some zones jiji and I needed to change a little bit the geometry
Thanks for your answer |
changing settings, fluent, fsi, simulation |
How to change the settings for FFD methods, please? | Xiaosong | SU2 | 3 | September 7, 2019 07:13 |
Error in phase change simulation | tomide | CFX | 20 | August 19, 2019 12:06 |
Simulation of a membrane distillation process (phase change and diffusion process) | fkika | OpenFOAM Pre-Processing | 1 | February 21, 2018 08:38 |
Simulation of Phase change material (PCM) and nanoparticles together | farah | Main CFD Forum | 0 | November 2, 2015 15:30 |
HP Turbine Flow simulation Solver settings | Puneet | FLUENT | 1 | August 10, 2003 06:00 |
