Meshing an aerofoil with serrated trailing edges using unstructured Mesh |
January 4, 2017, 16:42 |
Pianoman
I am having problems meshing (unstructured) an airofoil (2D) with a serrated trailing edge as the skewness is coming up to be very high. Any tips as to how I can approach the problem will be awesome.
January 9, 2017, 11:14 |
Same Problem
Misha Kustin
Hello, I am having the same problem. Working on a very similar airfoil and it seems to be the high skew comes from the meshing in between each serration and on the end of each serration. Still trying to fix it myself. The picture included highlights the cells that have a skew of over 0.85.
October 26, 2020, 15:57 |
Rep Power: 9 |
Hello, I'm facing a very similar problem, can you tell me how you solved it?
Thanks. |
November 1, 2020, 02:10 |
Arnie
Rep Power: 9 |
Modify the geometry slightly I.e. cut off the sharp trailing edge to give you a small blunt edge. Then apply an equivalent mesh size to that ‘blunt’ surface.
This change to the geometry will result in a better mesh and an insignificant change to your results. |
airfoil 2d, fluent, mesh 2d, serrations |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 02:37 |
[ICEM] Just started unstructured mesh ! | diamondx | ANSYS Meshing & Geometry | 6 | September 5, 2012 08:15 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
Meshing trailing edge of aerofoil | CC | Main CFD Forum | 7 | December 10, 2008 21:22 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
