Polyflow- Parameterize Torque and fowrate output
Old   December 20, 2016, 23:57
Default Polyflow- Parameterize Torque and fowrate output
jy
jy tey is on a distinguished road
Currently i work on extruder screw design optimization problem which uses polyflow to perform the simulation. Polyflow will calculate the torque and absolute flow rate output in the listing viewer file. However these parameters are not written in CFD-post output file. Which make it can't be parameterize for design exploration and optimization. It is also not available in output setting in polyflow setting.
Does any one know how to output the torque and flowrate out for parameterize?
I had try to write the python code &xml to read the text using external connection, however this method wont refresh the output read file when a new design is being evaluate.
jy tey is offline   Reply With Quote
flowrate, polyflow, torque
