How to ensure overall continuity is maintained in the domain?
Old   November 30, 2016, 20:51
Default How to ensure overall continuity is maintained in the domain?
William
Wingman is on a distinguished road
I am using Fluent to find Lift, Drag, Moment, Pressure Coeff etc. of an airfoil. The airfoil is small and the reynolds number is low (1 > 0.1 > M) so I'm assuming incompressible flow.
I'm using a pressure based solver and Velocity Inlet and Pressure Outlet boundary conditions. When changing the angle of attack the flow exits the domain at the Velocity inlet and I need to ensure that overall continuity is maintained in the fluid. How can I check?
Originally Posted by 7.4.3 Calculation Procedure at Velocity Inlet Boundaries
Sometimes a velocity inlet boundary is used where flow exits the physical domain. This approach might be used, for example, when the flow rate through one exit of the domain is known or is to be imposed on the model.
In such cases you must ensure that overall continuity is maintained in the domain.
In the pressure-based solver, when flow exits the domain through a velocity inlet boundary FLUENT uses the boundary condition value for the velocity component normal to the exit flow area. It does not use any other boundary conditions that you have input. Instead, all flow conditions except the normal velocity component are assumed to be those of the upstream cell.
Wingman is offline   Reply With Quote
Old   December 1, 2016, 07:56
Antanas is on a distinguished road
As far as I remember in Fluent you should calculate mass flow rate through your boundaries and make sure net flux is almost 0 (Postprocessing → Reports → Fluxes...).
Last edited by Antanas; December 1, 2016 at 08:07. Reason: Whoops! Missed that your question is about Fluent.
Antanas is offline   Reply With Quote
Old   December 1, 2016, 08:53
William
You are correct. Thanks!
inlet: 582.45357
outlet: -582.45357
Net -4.7293724e-09
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 06:41
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
