Ansys CFD POST constructs a solution history from wrong file.
Old   November 22, 2016, 05:01
Default Ansys CFD POST constructs a solution history from wrong file.
William
Wingman is on a distinguished road
When I load FileName_Run2.cdat into CFD POST it constructs a Solution History with FileName_Run1.cas.gz.
Same happens with FileName_Run2.cdat ... FileName_RunN.cdat.
How can I specify which is the correct one? I really wan't to keep those files within the same folder.
Wingman is offline   Reply With Quote
Old   November 22, 2016, 06:58
William
Here is the window!
Old   November 28, 2016, 18:01
William
Nobody here knows how to open Fluent results properly with CFD Post?
cfd post, load case error
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
