November 21, 2016, 05:10 |
Ansys workbench HPC
Rep Power: 14 |
Good morning , i have a big problem with my workstation . This mounth i have buy a new pc with 2 xeon e5 2658 v3 with 24 vores and 48 cores with hyper. But when i try to lunch a simulation with a simulation with statical structural solver , i see the cpu usage at only 4 % with 2 cpus that work...I try to find a solution , i read many post with hpc problem , but with no results. I see that my ansys have one hpc lincense , could anyone tell me a procedure for use all the cores in workbench static structural?
November 22, 2016, 05:43 |
Rep Power: 14 |
Ok, i found the solution , when i open the mechanical tub , under tools , there is solver option and i can set the cores'number and the gpu model. Now i have another problem , with my cpu ( 2xe5 2658 ) i have 24 phisic's cores and 24 logic cores...But if i set 48 cores , the usage goes only at 50%....Is there anyone that could help me?
November 23, 2016, 16:42 |
asdfad
Rep Power: 14 |
Hei, you have only 24 physical cores. Hyperthreading will not increase the speed of your calculations, more likely to slow them actually down.
November 24, 2016, 01:44 |
Rep Power: 14 |
Ah ok , i dont know it, another think, i read that the gpu could give a support. Now i have a gtx 970, could it function?
November 25, 2016, 08:16 |
Gwenael H.
Rep Power: 20 |
Not all the GPU are supported. For the Nvidia cards you should have either the Quadro or the Tesla series. You can find a description of the tested and recommended graphic cards bellow:
http://www.ansys.com/-/media/Ansys/c...-172.pdf?la=en Not to get into too much details, but the Quadro / Tesla have a lot more memory and have double precision plus are more “thoroughly” tested. You can still use a GTX for post processing, but not for calculation. |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 06:52 |
Export parameter from ANSYS Workbench into a Log-file | xtphgu | ANSYS | 2 | March 22, 2018 11:25 |
Ansys Workbench Thermal-Stress Coupling - 2D Hot Rolling simulation | Jeronimo97 | CFD Freelancers | 4 | August 23, 2014 21:30 |
error in opening fluent in ansys workbench | tmeysam92 | ANSYS | 3 | March 12, 2013 07:10 |
Ansys Workbench 10.0 | Merkur | CFX | 1 | June 16, 2006 07:19 |
