Ali Jamali
Rep Power: 9 ![]() |
I am trying to get a sphere to deform and pass through a choke-like flow path. I am very new to both ANSYS and FSI system coupling. I have read/watched many tutorials to make this model; however, I think I have either messed up or not quite understood parts of the physics of the problem and that's why it does not converge. I have attached 4 pictures of how the sphere moves upward until the simulation stops at t = 0.4 sec with the following error:
Fluent encountered fatal error after sync pint solve: update-dynamic mesh failed. Negative cell volume detected. Ideally, and based on the physics of my problem, I would like the sphere to either stop or deform and pass through the choke. What am I doing wrong here? Here is a link to the simulation model The ultimate goal is to simulate something like this video except that in my case it's a solid moving inside a fluid medium. Last edited by alijamali; November 17, 2016 at 16:22. Reason: Adding a YouTube video |
Ali Jamali
Anybody? Please.
Rep Power: 13 ![]() |
Negative volume error represents moving mesh issues and resulting unreal mesh elements due to self-intersection.. Have you tried simulating with a model where radius of the ball/ sphere is shorter than the channel? I would think of that working pretty fine without any significant changes in your current model mesh quality..
From top of my head, actually the only way you could simulate this with the moving/ dynamic mesh method is if the circular body is allowed to pass through the channel, the gap however could be extremely minor... on the other hand, this simulation could be divided into 2 parts: (i) ball upward movement by virtue of flow till the very last element possible (ii) ball stuck in the channel (this should be fairly simple & straightforward).. |
Ali Jamali
Thank you fresty for your response. I would seriously consider breaking the problem down into two parts as you suggested; however, I preferred if I could see how the sphere interacts with the wall and with the fluid, deforms, and passes through the flow restriction. In fact, the whole purpose of this simulation is to observe pass and stop modes as wells as pressure profile through the throat.
I initially assumed that the sphere was a rigid body (without watching the linked video)... once again, even if the sphere is deforming (like it is in the video), to support dynamic mesh simulation in ANSYS, it would be essential that you begin with a model having sphere size smaller than the channel (as it is in the video).. in this case, you would do well without breaking the simulation down into two parts..
the problem only arises IMO once 'zero' mesh is encountered at the corners.. once the smaller sphere problem works fine, you could parameterize the geometry and simulate accordingly.. |
Simple FSI (fluid structure interaction) Problem | kilroy | Main CFD Forum | 0 | January 7, 2015 14:42 |
FSI Structural convergence problem | Blizzard99 | CFX | 13 | December 23, 2014 03:45 |
Problem with FSI Boundary Condition | ashtonJ | CFX | 6 | June 28, 2012 04:28 |
fsi problem | berelian90 | CFX | 0 | October 19, 2010 07:30 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
