November 14, 2016, 10:20 |
Commands (APDL)
Olivier Carrière
Hi everyone,
I'm doing a harmonic analysis on a system using the full method of resolution. As always i use the cyclic symmetry but this time, my load is a non-cyclic force. As far as I understood, i have to use a commands (APDL) where i should write this : CYCOPT,LDSECT,1 !because my force has to be only on the first sector SFL, ALL, PRESS, 10000 !to have a pressure on all my sector. As i run the project, i don't get any deformation as if there were no load .... Does anyone know what i'm doing wrong ? Thank you in advance ! |
macro, mapdl, non cyclic load |
[ANSYS Meshing] Export meshed part in ICEM to ANSYS APDL | Alam Swift | ANSYS Meshing & Geometry | 0 | May 21, 2016 09:04 |
[Workbench] Symmetry (APDL command) in Workbench? | A7A | ANSYS Meshing & Geometry | 0 | May 8, 2016 04:16 |
Save picture from Execute commands and journal files | FJSJ | FLUENT | 0 | January 29, 2015 09:56 |
Combine WB and APDL Mechanics - which licences? | Marabelle | ANSYS | 10 | July 22, 2013 10:32 |
Please explain this commands. | sri31049 | FLUENT | 3 | March 20, 2009 05:38 |
