Measuring forces on a specific face of aerofoil
Old   November 8, 2016, 06:16
Exclamation Measuring forces on a specific face of aerofoil
Craig
ced30 is on a distinguished road
Hi there,
Problem in the program CFX-Post with a FLUENT .dat file.
Setup:
Transient analysis of a custom wind turbine blade. Rotating around the hub (not modeled).
Imported blade geometry, created new plane and body operation (move) in order to ensure the axis of rotation was correct, created two enclosures, a sphere (rotating domain) and box (stationary domain). Then a Boolean to remove the blade from the sphere to create the solid.
Named Selections: Inlet, Outlet, Box Wall, Sphere Interface
Problem:
The simulation runs fine and results are as expected, but I was looking to perform some more in depth analysis. The blade (pictured) is quite a complex shape, but I was hoping to get the forces acting on the blade top surface and bottom surface. Before in a previous problem with a fan blade, I created a line across the blade surface and plotted the pressure results, but this is not possible in this scenario due to the twist angle.
In short, is it possible to select a specific surface in CFX-Post to perform Function calculations on? Or ideally create a line that follows the surface of the blade?
Apologies if this problem seems basic but can't quite figure out how to do the problem.
Thank you for your help!
ced30 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Error message: 8 face(s) not in face lists of adjacent cells jyoung79 FLUENT 0 November 10, 2012 17:09
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
